Country: Machine Setter
Responsibilities Support daily production engineering activities within the machine shop and manufacturing environment. Create...Are you an experienced Production Engineer, Manufacturing Engineer, or Industrial Engineer...
About the role We are looking for a Controls Engineer to join our engineering team at the Ambrosia Creamery. You will support... technical issues clearly and maintain accurate records. Experience in food manufacturing, process plant or packaging equipment...
on the shop floor. This role would suit a Design Engineer from a machinery background looking to apply their skills... with any CAD package Commutable to Bradford Reference: BBBH27026AF1 Keywords: Design Engineer, CNC, Machine Tools, Mechanical...
Multi-skilled Maintenance Engineer Application Deadline: 25 November 2026 Department: Andover Supply Centre.... You will underpin manufacturing operations at the Andover site by conducting plant maintenance activities to achieve targeted levels...
Position Summary Magellan Aerospace Blackpool has an exciting opportunity for a Production Engineer. Full Time... is governed by ITAR, restrictions may apply To deliver the Production departments support requirements of the manufacturing...
lubricants Must Have - Understanding of CNC machining, machine shop environments, manufacturing operations or precision.... Working closely with machine shop, you will be responsible for identifying opportunities, providing technical recommendations...
This is an excellent opportunity to join a highly skilled machine shop team in Gloucestershire, working on complex, high-precision..., you will be responsible for producing CNC programs and all supporting documentation for the shop floor. You will support the wider machine...
Engineer Please note this position will be on a 3-shift rotation, alternating weekly between afternoons (14:00-22:00... OEE target and above. Shop floor support for all processing issues. Support new product launches and attend R@R...
the first cut. As a CNC Programming Engineer, you'll write the programs that turn designs into reality on the shop floor...Job Description Summary Job Description CNC Programming Engineer Why This Role Matters Precision starts before...
